Our smallest wireless probe to date for workpiece and tool measurement in CNC machine tools. It is deployed in compact milling, turning and millturning centres used for microprocessing, medical technology and the measurement of components on machines for additive manufacturing.
TC55 – Ultra-compact all-rounder with infrared transmission
  • Applications
  • Features
  • Accessories
Wear-free, optoelectronic signal generation
  • The trigger signal is generated via shading of a miniature light barrier
  • Enables much higher measuring speeds and accuracy than with conventional probes
  • Wear-free with long-term stability
Patented and face-geared shark360 measuring mechanism
  • Face-geared measuring mechanism
  • Maximum measuring accuracy even with off-centre probing
  • Enables pulling and torsion-exposed measurements
  • Constant deflection forces
  • No preferred direction
Reliable and proven transmission technology
This touch probe is available with infrared technology:
  • Extremely fast and reliable transmission
  • Sequential use of 2 infrared measuring systems with one receiver (DUO mode)
  • Smallest wireless probe from BLUM
Additional information
Position measurement
Fast determination of current workpiece position (workpiece zero point) prior to machining or after resetting using digital (switching) measurement.
Measurement of standard features
Digital (switching) measurement of distances, single points, angles, inside and outside diameters, inside and outside widths on a manufactured workpiece.
Pulling measurement
Fast measurement of inside widths, outside widths and recesses using pulling/pushing measurements in Z+/Z- with the help of cranked styli.
Workpiece inspection
Inspection of the manufactured workpieces for machining errors and adherence to manufacturing tolerance by means of control measurements prior to clamping.
Torsion-exposed measurements
Unlike conventional touch probes, the unique shark360 measuring mechanism also allows for measurements in which a torsional force acts on the measuring mechanism.
Adaptive machining
Determination of parameters for adaptive machining and process control between and after the machining steps.
Coolant load
Reliable and fast measurements in the coolant thanks to modern measuring mechanism with increased measuring force.
Single & mass production
Perfectly suitable for mass production under the harshest conditions thanks to robust design and protection class IP68.
Wear compensation
Tool wear is compensated for by taking measurements on the workpiece and comparing these with the nominal dimension.
Temperature compensation
Compensation of the temperature-dependent thermal behaviour of machining centres.
Further product features
  • High-quality stainless steel housing
  • Max. probing speed: 2 m/min
  • Repeatability: 0.3 µm 2σ
  • Protection class: IP68
  • Approach directions: ±X, ±Y, ±Z
Receiver systems
For wireless data transmission between BLUM measuring systems and the machine tool, compact receiver systems incorporating the latest transmission technologies are used.
Quickstart measuring cycle packages
Quickstart measuring cycles for BLUM workpiece touch probes are user-friendly subroutines of the machine control. They can be used for workpiece referencing as well as for measuring during the production process.
The following measuring cycle packages are available for the touch probe:
  • Quickstart
  • Quickstart T
  • Quickstart Z
  • Quickstart M
Applications
The compact infrared probe is perfect for small milling and turning machines.
Workpiece measurement in a CNC milling machine
Fast workpiece measurement in a lathe
